DaddyGuy969
Dec 06, 2021Follower
RBS750 Orbi Satellite Problems with Backhaul and Lights
I purchased two RBR750 sytems and pulled the two extra satellites to one system. So my current system consists of the RBR750, and 4 RBS750s. One of my Satellittes is does not seem to be working lik...
Dec 06, 2021Guru - Experienced User
Be sure FW is all the same version on RBS as whats loaded on the RBR.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Power OFF the working RBS then bring the other non working RBS to same room as the RBR and resync them there. You might "Disconnect" the non working RBS from the RBRs web page first, then resync them one at a time.
