DaddyGuy969
Dec 06, 2021Follower
RBS750 Orbi Satellite Problems with Backhaul and Lights
I purchased two RBR750 sytems and pulled the two extra satellites to one system. So my current system consists of the RBR750, and 4 RBS750s. One of my Satellittes is does not seem to be working lik...
CrimpOn
Dec 07, 2021Guru - Experienced User
DaddyGuy969 wrote:
I pulled the non-working satellite up by my RBR. Tried to do a factory reset on it, but didn't seem to reset anything. I have reconnected to my RBR, and noticed that it is using a 2.4Ghz backhaul now, not the 5.0Ghz, like the rest of mine are using, and this one is real close to the RBR. It also doesn't seem to be using the Ethernet when connecting directly to it.
It is connected though, and the light on my Satellite is glowing Blue. However, the light does not seem to turn off anymore. I think it is supposed to turn off after 3 minutes of being connected.
A little more description would help me to understand the situation.
The two satellites which originally had 5G backhaul and were changed to wired backhaul continue to be fine.
The third satellite which originally had 5G backhaul and continues to use 5G backhaul is fine.
The fourth (non-working) satellite:
- Has been physically moved (pulled up) to the router. (in the same room)
- When the satellite was turned on again, what was done to 'reconnect' it to the router? (just power it on and it happened automatically?)
- The router Attached Devices page shows it connected at 2.4G rather than 5G.
- When an ethernet cable was connected between the router and satellite, the satellite does not switch to wired backhaul.
- The ring light continues to glow blue even though more than three minutes have gone by.
If this is correct, then it might be worth starting over:
- Power off the satellite, and when it shows "offline" click on the option to remove it.
- Use a paperclip to do a Factory Reset on the satellite, being careful to observe the power LED turn amber and then begin to flash.
- After it restarts, use the "Add Orbi Satellite" menu option and reconnect it to the router (follow the steps).
