jcut323
Nov 14, 2024Follower
RBS750 RESTARTING//Endless flashing white light + Intermittent DC Solid Green/orange/blank/Green
I have an RBR750 and RBS750. Problem upfront: RBS750 is flashing white and will not connect to router. It appears to be in a constant reboot cycle. The DC light will appear solid green for 1-2 m...
Nov 15, 2024Guru - Experienced User
Avoid using v.31 FW for Orbi AX and AXE systems.
Been too many users posting having problems with it.
v.21 is most stable version of FW.
Try this for loading FW on any RBS that won't connect:
Might try a 30-30-30 reset on RBS that you can't seem to get fully connected too.
Revert ANY RBS back to v.21 then downgrade the RBR unit lastly to v.21.
Factory reset and setup from scratch with a wired PC and web browser:
Be sure to disable the auto update feature on the RBR to prevent the system from updating back to v.31.
