bosscharles
Apr 03, 2023Aspirant
RBS750 satellite bricked by firmware V4.6.14.3
Kit recently updated automatically to firmware V4.6.14.3. Router is fine, so is one other satellite. The second satellite just flashes white. Reset makes the satellite go amber for a few seconds and ...
bosscharles
Hi, thanks for the response, unfortunately that didn't work either. I think the bootloader got messed up. It's been RMA'ed now.
Kind Regards,
Charles
Apr 03, 2023Guru - Experienced User
Sounds good, was going to be my next suggestion. Glad there taking care of you.
Good Luck.
