astainback
Jan 27, 2021Apprentice
RBS750 Satellite Connection - GOOD/POOR
Just curious... I read on this community about checking backhaul status and I only see where it is GOOD. Is there a way to see the signal strength or the speed of the connection or is GOOD in the co...
- Jan 27, 2021
Thats about the only area that you can.
You can try this on the RBS and see;
If you can gain access to telnet, try iwconfig ath0, ath1 and ath2
Jan 27, 2021Guru - Experienced User
astainback
Thanks again Furry.
I don't need to check it. I was just curious.
- FURRYe38Jan 27, 2021Guru - Experienced User
:smileywink:
