Sameem
Jan 06, 2025Aspirant
RBS750 Satellite Disconnecting at random times
Hi Guys, My RBS750 satellite keeps disconnecting and then reconnecting at random times. So when I playing on my PC is see the light of the satellite pulse white and then it shows the blue light aga...
- Jan 07, 2025
Would be suggested...
Jan 06, 2025Guru - Experienced User
Users have posted having problems with v.31 FW after it's been loaded on a system. We recommend downgrading the RBS first, then RBR lastly to v.21 as this version is most stable to date. You'll need to factory reset the system then setup from scratch:
Soon after be sure to disable the auto update feature on the RBRs web page as to not let v.31 get re-applied.
