msaidy
Aug 23, 2022Aspirant
RBS750 Satellite Green Power LED Light off
Hello, One of my two RBS750 Satellites is completely dead. The Green Power LED Light is off when plugged to different outlets and using the other power cord from the working Satellite. Can this...
Aug 23, 2022Guru - Experienced User
Contact NG support and see, I don't believe they repair units, rather replace them with an RMA if thats an option.
https://my.netgear.com/support/contact.aspx
- msaidyAug 23, 2022Aspirant
Thank you for the prompt response. Sorry, should have stated that that both my product hardware warrantly and technical support expired. I think this would mean an RMA ticket woudl not be an option. What are my options other than RMA? Doe this mean I have to buy a new unit? Thanks.
- FURRYe38Aug 23, 2022Guru - Experienced User
Probably.
Hello,
I clicked on the NG Support link. It is prompting me to purchase one of their GearHead contract/support plans $89.99, $139.99 or $229.99. Do I have to purchase one of those plans to just ask a question if my unit could be repaired or need to be replaced?
