msaidy's avatar
msaidy
RBS750 Satellite Green Power LED Light off
Hello,   One of my two RBS750 Satellites is completely dead.  The Green Power LED Light is off when plugged to different outlets and using the other power cord from the working Satellite.  Can this...
  • FURRYe38's avatar
    NG seems to be pushing extra services. I won't recommend that at this point.
    You might reach out to a forum moderator and see if they can help you. Send them a Private Message.
    Blanca_O KevinLiT
