eddinfla's avatar
eddinfla
Follower
Feb 05, 2024
RBS750 satellite morte
My RBS750 satellite was dropped.  Now Dead as a doornail, no power light.  Took it apart hoping for some evidence of a loose wire or anything.
No joy.
Any ideas aside from "get a new one"?
Thank you.
  • FURRYe38's avatar
    Try a different power supply.
    If you can get it to power up any, try a 30-30-30 reset.
    If this fails, find another one.
    Good Luck.
  • plemans's avatar
    Also look closely at the power jack. I had my kids knock a router off a shelf. It cracked the board the power jack was attached to. I soldered a little jumper from point to point and it worked fine. took a little bit to find though
