atorres224
May 29, 2023Aspirant
RBS750 Satellite not connecting at all
My RBS750 satellite no longer shows up on my network at all, either on the app or on the website. I moved it right next to the Orbi router but it still does not sync. I factory reset it using a paper...
CrimpOn
May 29, 2023Guru - Experienced User
If the satellite no longer appears on the Attached Devices, did you select the menu item "Add Orbi satellite" (bottom menu item) and follow the directions? (This involves pressing the sync button on both the satellite and the router in the correct sequence.)
- atorres224May 29, 2023Aspirant
Yep, I tried it on the app as well as on http://192.168.1.1/ but it still isn't recognizing it. I tried pressing the sync button on the satellite and then the router and then vice versa.
- CrimpOnMay 29, 2023Guru - Experienced User
I'm guessing you posted on the forum because the 90 days of 'complimentary support' have expired. Is the satellite within the one year hardware warranty? If so, I would contact netgear about a Return Material Authorization (RMA). Start by logging into my.netfgear.com , select the equipment, then click the button Request Hardware Support.
If it is more than a year old, then it may be possible to reflash the satellite firmware. Not a trivial process.
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
Some people prefer the nmrpflash program:
https://github.com/jclehner/nmrpflash
There are videos:
https://www.youtube.com/watch?v=R9DLrLQrpaw
Yep, over 1 year from date of purchase. I will try to reflash the satellite firmware with the steps you provided below.
Thank you so much for your help!
Best,
Alex
