atorres224
May 29, 2023Aspirant
RBS750 Satellite not connecting at all
My RBS750 satellite no longer shows up on my network at all, either on the app or on the website. I moved it right next to the Orbi router but it still does not sync. I factory reset it using a paper...
atorres224
Yep, I tried it on the app as well as on http://192.168.1.1/ but it still isn't recognizing it. I tried pressing the sync button on the satellite and then the router and then vice versa.
CrimpOn
May 29, 2023Guru - Experienced User
I'm guessing you posted on the forum because the 90 days of 'complimentary support' have expired. Is the satellite within the one year hardware warranty? If so, I would contact netgear about a Return Material Authorization (RMA). Start by logging into my.netfgear.com , select the equipment, then click the button Request Hardware Support.
If it is more than a year old, then it may be possible to reflash the satellite firmware. Not a trivial process.
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
Some people prefer the nmrpflash program:
https://github.com/jclehner/nmrpflash
There are videos:
https://www.youtube.com/watch?v=R9DLrLQrpaw
- atorres224May 29, 2023Aspirant
Yep, over 1 year from date of purchase. I will try to reflash the satellite firmware with the steps you provided below.
Thank you so much for your help!
Best,
Alex
