Jimanator
Jun 18, 2020Guide
RBS750 satellite wireless not working?
Help...I know the unit is connected to the router, because I am able to use via the ethernet jacks in the satellight. The problem is the wireless function of the satellite unit is not working.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?How can you tell the wifi is'nt working on the RBS?
What does the status report in the RBRs web page?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerHas a factory reset and setup from scratch been performed since last FW update?
Press the back reset button for 15 seconds then release.V3.2.15.25 firmware
ATT Uverse5268 AC router
Wifi not working upstairs
Status is green
what's plugged into the satellite connects to the main router.
What mode is the modem working in? This modem has a built in router and wifi.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-ModeWhat devices are you trying to connect?
Is the RBS wireless connected to the RBR if it is then wifi is working at the RBS.
Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings on the RBR.
Try disabling AX mode on the RBR as well.
