JohnDucker
Dec 20, 2021Guide
RBS750 Satellite won't connect to router
I have an RBR750 and three RBS satellites running the latest firmware. Has been stable for about six months, but recently one satellite lost contact to the router. Ring LED solid magenta. I have trie...
- Dec 20, 2021
I am no expert but I just solved my problem as follows:
1. Brought faulty satellite into same room as RBR750 router
2. Plugged satellite in and waited for a solid white light (appreciate yours is flashing - maybe just wait two mins for boot up then try the next step anyway)
3. Pressed factory reset button with paper clip and held it depressed for 20s. The power LED flashes red after about 5s but I kept it depressed. Release paper clip - satellite ring LED falshes white.
4. When ring LED went solid white on satellite, I pressed sync button on satellite, then on router. Both ring LEDs flash white.
5. After about 90 secs the satellite showed up on the app network map and on the device map on the router web page. Satellite ring LED went solid blue (A GOOD THING!)
6. I checked the firmware version on the webpage and my satellite was out of date, so I went through a firmware update. This disconnected the satellite again, so I had to repeat steps 1.- 5. and this time the satellite stayed connected with the right FW version
Hope this helps
JohnDucker
Dec 20, 2021Guide
I did turn off the other satellites and brought the problem one to the same room as the router. I am not sure what FW version the router is on as I cannot communicate with it?
Dec 20, 2021Guru - Experienced User
You can't connect to the RBRs web page or RBS web page?
If you bring the RBS to same room, power it ON after connect it to the RBR using a ethernet cable?
- JohnDuckerDec 20, 2021Guide
I can connect to the router web page and can see the RBR and two working satellites. All are at latest firmware version. Cannot see the faulty RBS. I tried direct ethernet connection between router and RBS but didn't help.
Now I tried another factory reset on the RBS
It flashed white for several minutes after the RBR went back to solid white.
During this time it did show up as a connected device - first hardwired (which it was not), then as a 2.4G connection. I checked the firmware and the faulty RBS was showing V.4.6.3.7 firmware so I pressed "Update all", but the satellite disconnected again. Now just showing a constant white ring.
- FURRYe38Dec 20, 2021Guru - Experienced User
Can you get the RBS to connect again then see if it has a IP address next to it listed on the RBRs web page. If it does, you might beable to access the RBS web page using it's IP address, if you can, have the Same version of FW that the RBR is using and have this RBS FW file ready on your connnected PC. I'd wire connect the PC to the back of the RBS for a more direct connection. Send the FW file to the RBS direcly using the RBS web page.
Seems like the RBS FW is not using same version as RBR and other RBS. Possible the RBS update maybe corrupt as well.
- jashgDec 20, 2021Aspirant
Hi, have the same issue - RBK753 with an additional satellite (4 in total) all working fine for 6 months then one of the satellites failed to connect. I have tried reconncting multiple times including resetting the satellite and no success - it constantly shows the flashing white light that looks like it is waiting to pair with a router. I bought another satellite and when I try to add that to the router, it fails to find it. I am at a loss as to what to do next as I think I have faulty hardware that is in warranty but cant see how to get in touch with netgear to get help or a replacement. Any help of pointers about what to try next would be much appreciated.
Thanks for all your help on this, but how do I download a FW file to my laptop and then upload it to the RBS?
Ignore that request - I found the manual and downloads on the website. I tried another factory reset and sync and this time the faulty satellite has remained connected (10 mins and counting) and is showing the correct FW version. Fingers crossed this has fixed it. Will let you know tomorrow. Thanks SO MUCH FURRYe38 for all your advice
Hope this helps
3. Pressed factory reset button with paper clip and held it depressed for 20s. (Usually 15 seconds is max press time.) The power LED flashes red after about 5s but I kept it depressed. Release paper clip - satellite ring LED falshes white.
6. I checked the firmware version on the webpage and my satellite was out of date, so I went through a firmware update. (I recommend manually downloading the FW file and manually sending the FW file to the RBS. He's ensure a good FW load using a wire connected PC. https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satellite) This disconnected the satellite again, so I had to repeat steps 1.- 5. and this time the satellite stayed connected with the right FW version
RBS should be updated first always, then the RBR lastly.
Awesomeness. Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
