ckeyes888
Jul 06, 2022Follower
RBS750 Satellite Won't Connect
Hey, Have a 2 satellite RBS750 system that one of the satellites stopped working. I've tried pressing the reset and moving it right next to the base unit but nothing is working. Any help greatl...
Jul 06, 2022Guru - Experienced User
Try removing the RBS entries on the RBS web page under Connected devices then reboot the RBR. Factory reset the RBS by pressing the reset button for 15 seconds then release.
Re-sync manually using the sync button on the RBS and RBR while you have the RBS in the same room as the RBR. Sync one at a time.
