mac143
Apr 06, 2023Follower
RBS750 Satellite won't sync after a power outage - It will only flash white slow and fast
RBS750 router and one satellite came back after a power outage. The other satellite started flashing white. We have powered it off and on and gone through syncing every way we can find. On the bac...
Apr 06, 2023Guru - Experienced User
Did you try removing the RBS from the RBRs web page while the RBS is turn off, then bring the RBS to the same room as the RBR and then try to re-sync the RBS using the sync buttons in back?
Also try ethernet connecting the RBS to the back of the RBR with a LAN cable.
