home_alone
Jul 15, 2022Tutor
RBS750 satellite
Can I connect the router to one satellite via ethernet for better connectivity? Are the satellites POE compatible or do they need an external power supply?
Jul 17, 2022Guru - Experienced User
home_alone wrote:
Can I connect the router to one satellite via ethernet for better connectivity? Yes.
Are the satellites POE compatible or do they need an external power supply? No.
