harishe
Sep 20, 2021Initiate
RBS750 satellites show backhaul status out of sync
I have Netgear Orbi RBS750 Router with 2 satellites (Bought from Costco). I see sometimes one of the satellite goes into out of sync status in the backhaul. I am using the latest firmvare version V4...
harishe
Home size is ~2750 sqft.
Distance between router and satellites is more than 30 feet and the walls are standard sheetrock walls.
Yes the setting is enabled for both 2.4 and 5GHz bands.
By the way backhaul status when it shows under the "Advanced | Attached Devices" show good sometimes, out of sync is intermittent.
Sep 20, 2021Guru - Experienced User
Try moving the RBS just a bit closer. Maybe 5 feet?
- alphansteinSep 21, 2021Guide
Check your firmware on each satellite. I had one that did not update to .16 firmware and it was exhibiting this behavior, but now works after I did a manual update to it. You should be able to see it in the web app or just log into the IP address of the satellite directly.
