Thewookiee
Sep 10, 2022Follower
RBS750 Slow Speeds wireless and wired
Trying to resolve why within the last few weeks all of a sudden my satellites has become slow and periodically unresponsive. Nothing has changed in position or router or satellites. This is both wirel...
Sliu73
Sep 11, 2022Aspirant
I have the same problem, I tried updating to the latest firmware and still slow
I used to consistently get 1-200 Mbps, but now only about 15Mbps. No change in satellite position, no new devices
Started 1-2 weeks ago but
- Sliu73Sep 11, 2022AspirantSatellite is connected to router using 2.4GHz
- ekhalilSep 11, 2022MasterSatellites connected on 2.4 GHz band will for sure cause lower speeds for the devices connected to those satellites.
Please get the satellites closer or remove any obstacles in between. Another way is -if possible- use cables in between. You can also use Ethernet over powerline if possible.
