51Alan's avatar
51Alan
Guide
Aug 25, 2021
RBS750 Solid blue light
I have an Orbi RBK753 system with the two satellites daisy-chained, running firmware 4.6.3.7.  Starting a few days ago, the blue light on the RBS750 that is the first in the daisy-chain went on and continues to stay on (the light on the second RBS750 is not on).  Why would that be?  I am not noticing any change in performance.
1 Reply
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
