Tyson2busy
Oct 24, 2023Follower
RBS750 stuck in loop and can’t find static IP
Hi Guys, Please help me. I’ve been working on this for 3 days now and I absolutely need this extra satellite. The other issue is I’m in Bangkok Thailand (I’m American, bought the unit from Costco i...
Oct 24, 2023Guru - Experienced User
Be sure your setting a static IP address on the laptops network adapter configuration to same subnet for the RBS.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
Make sure you enable tftp: https://www.thewindowsclub.com/enable-tftp-windows-10
Video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done:
https://www.youtube.com/watch?v=hXhMgQS5k1o
https://www.youtube.com/watch?v=R9DLrLQrpaw
Mac TFTP: https://www.petenetlive.com/KB/Article/0001247
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/SOLVED-Steps-for-debrick-unresponsive-R7000-softbricked/td-p/414034
https://community.netgear.com/t5/Orbi/Solution-to-fix-Orbi-Satellite-flashing-white-forever-failed/m-p/1623284/highlight/true#M39130
Try nmrpflash:
https://github.com/jclehner/nmrpflash
