DaveyS_UK
Jul 04, 2023Follower
RBS750 WiFi drops despite AirPort Utility showing signal
I've got an Orbi RBS750 setup with 2 satellites, using ethernet backbone into the router as well as into each satellite. I get regular WiFi drops from each device. Using the iPhone with AirPort Utili...
Jul 05, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router and 📡 satellite(s)?
How are the RBS connected to the RBR via ethernet? Directly to the back of the RBR or is there a LAN switch in between them?
What CAT# lan cable are you using? CAT6 is recommended.
What is the Mfr and model# of the ethernet switch in the configuration?
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
