CARIB909
Mar 23, 2023Follower
RBS750 will not connect
1. I don't know what group to post in because none of the ones available have a name that reflects the mesh system I have. I don't know that it is a wifi6 router yet. The main router is RBR750. My s...
Mar 23, 2023Guru - Experienced User
Be sure FW is same version as whats loaded on the RBR...
CARIB909 wrote:
1. I don't know what group to post in because none of the ones available have a name that reflects the mesh system I have. I don't know that it is a wifi6 router yet. The main router is RBR750. My satellite is RBS750. Neither of these show up on the list of possible sections.
My problem is that nothing I do will get the satellite to connect to the router. I have pressed the reset button on the satellite for 30 seconds, but nothing happens. The light still flashes white. I moved the satellite close to the router and tried to SYNC, but that doesn't work. I deleted the satellite from the app and tried to add it back with no success. I don't see the satellite to add it.
