Sev97
Aug 29, 2021Aspirant
RBS750 Will not factory reset
Just bought another RBS750 and it constantly reboots all day. I have another RBS750 which works fine. I've tried factory resetting the satellite but it always just boots back up and re-connects to the router again. Is there a way to actually reset so I can go through the intial setup again?
Nick
1 Reply
When you reset it, turn it off and wait for the Disconnect to be seen on the RBRs web page. Select the Remove button. Apply and reboot the RBR. Power ON the RBS, you should be able to sync by hitting the sync button on the RBS first then the RBR.
