mondrin's avatar
mondrin
Guide
Nov 28, 2022
RBS750 won't connect after firmware update
I have a CBR750 and RBS750 which I purchased as a set.  I got notified that the RBS750 had a firmware update.  I believe it was running 4.6.5.14 which was quite a bit older than the 4.6.11.1 which I ...
  • mondrin's avatar
    mondrin
    Nov 28, 2022
    A bit of lucky searching found my problem.  Since I have a CBR750/RBS750 combo I should not be using the RBS750 firmware updates found on that page.  I need to use the CBK752 page and it's firmwares (Which were correct before).  After putting the correct RBS750 firmware for my set on the box, everything started working again.  Sorry to waste everyone's time.
