mondrin
Nov 28, 2022Guide
RBS750 won't connect after firmware update
I have a CBR750 and RBS750 which I purchased as a set. I got notified that the RBS750 had a firmware update. I believe it was running 4.6.5.14 which was quite a bit older than the 4.6.11.1 which I ...
- Nov 28, 2022
A bit of lucky searching found my problem. Since I have a CBR750/RBS750 combo I should not be using the RBS750 firmware updates found on that page. I need to use the CBK752 page and it's firmwares (Which were correct before). After putting the correct RBS750 firmware for my set on the box, everything started working again. Sorry to waste everyone's time.
mondrin
Nov 28, 2022Guide
I used the IP scanner to locate and log into the RBS750. It shows the desktop that is connected via ethernet but nothing to WIFI. It does show the current 4.6.11.1 firmware. I'm contemplating loading the older firmware that matches the CBR750. There aren't any other settings to manage via the RBS750 page so I don't know what else to try.
mondrin
Nov 28, 2022Guide
