mondrin
Nov 28, 2022Guide
RBS750 won't connect after firmware update
I have a CBR750 and RBS750 which I purchased as a set. I got notified that the RBS750 had a firmware update. I believe it was running 4.6.5.14 which was quite a bit older than the 4.6.11.1 which I ...
- Nov 28, 2022
A bit of lucky searching found my problem. Since I have a CBR750/RBS750 combo I should not be using the RBS750 firmware updates found on that page. I need to use the CBK752 page and it's firmwares (Which were correct before). After putting the correct RBS750 firmware for my set on the box, everything started working again. Sorry to waste everyone's time.
ScottSt
Dec 25, 2022Guide
Please disregards my previous post.
Shortly after posting I was able to track down the IP assignment for my RBS750. I connected to the Web UI and was able to revert back to firmware v4.6.5.14 and now it is once again showing as connected in the CBR750 web UI. All is good.
Dec 25, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- ScottStDec 25, 2022GuideThank you! Great suggestion and done.
