mondrin
Nov 28, 2022Guide
RBS750 won't connect after firmware update
I have a CBR750 and RBS750 which I purchased as a set. I got notified that the RBS750 had a firmware update. I believe it was running 4.6.5.14 which was quite a bit older than the 4.6.11.1 which I ...
- Nov 28, 2022
A bit of lucky searching found my problem. Since I have a CBR750/RBS750 combo I should not be using the RBS750 firmware updates found on that page. I need to use the CBK752 page and it's firmwares (Which were correct before). After putting the correct RBS750 firmware for my set on the box, everything started working again. Sorry to waste everyone's time.
Jan 06, 2023Guru - Experienced User
FYI for everyone:
ScottSt
Jan 06, 2023Guide
This is great FURRYe38, and extremely helpful. Thank you!!
However, only for those who happen to find this blog page.
I still think if Netgear is going to release different firmware versions, depending on the hardware configuration, they need to have it do a check of that configuration and flag if not supported or will cause problems.
- FURRYe38Jan 06, 2023Guru - Experienced User
Does make sense to have something on the CBR to check this. However may not stop someone from manually updating the RBS directly thru it's web page, though I presume something could be done here as well to check if the RBS is connected to a CBR. I'll pass this onto NG for review.
