CarlJohnDensley
Sep 07, 2022Aspirant
RBS750 WONT CONNECT AT ALL
thuis device has worked fine for a year. I have done the amber reset a number of times. Pushed the sync button etc etc. Tried to ad it as a new satellite but nothing. It does not find the device. Thi...
Sep 07, 2022Guru - Experienced User
Can you ethernet connect it to the RBR and see if it gets an IP address from the RBR?
What FW version is loaded on the RBR?
You'll need to make contact with NG support if you can't get the RBS recovered:
