CarlJohnDensley
Sep 07, 2022Aspirant
RBS750 WONT CONNECT AT ALL
thuis device has worked fine for a year. I have done the amber reset a number of times. Pushed the sync button etc etc. Tried to ad it as a new satellite but nothing. It does not find the device. Thi...
ekhalil
Sep 07, 2022Master
CarlJohnDensley wrote:...... I have done the amber reset a number of times. Pushed the sync button etc etc. Tried to ad it as a new satellite but nothing. .....
This can be a faulty HW, but can also be an IP or radio issue. Can you please explain your setup. What ISP modem/roter are you using? Is Orbi in AP or Router Mode? Is this your only satellite? Is the router working well, taht is devices connecting to router are ok? ....
