tomhutchings
Sep 21, 2021Star
RBS750 won't connect to RBR750 Router (after factory reset)
Hi. My Orbi RBK750 (Router + 2 Satillites) have been work relatively well since I brought them in May 2021. One satillite node has been doing random reboots and disconnects and now a week ago wo...
Sep 27, 2021Guru - Experienced User
I'd open a support ticket and let NG know whats happening.
You might downgrade the RBS back to v7, factory reset them and try to resync them. I'd remove the RBS from the RBRs web page, then re-sync...https://community.netgear.com/t5/Orbi-WiFi-6/New-Online-Update-4-6-3-16-RBR850-RBS850/m-p/2144453/highlight/true#M20754
tomhutchings
Sep 27, 2021Star
Thanks again... seems that I've got to pay for support after 90 days :-( Will have a look at the cost
- FURRYe38Sep 27, 2021Guru - Experienced User
Let us know if downgradnig the RBS changes anything, if not, try downgrading to v3.
