Number2
Jan 03, 2024Aspirant
RBS760 AP MODE not working right, best hardwired signal?
Hello,I recently bought the Orbi RBS760 router and 2 satellite, I only had a xfinity modem/router for a work from home/gamer house ,found out we had over 35 devices on just that router and wasn't gett...
- Jan 04, 2024
The ISP gateway router needs to be in router mode, not bridge mode, if you use the Orbi system in AP mode.
Jan 03, 2024Guru - Experienced User
The ISP gateway router needs to be in router mode if you use the Orbi system in AP mode. If you can put the ISP gateway into bridge or modem only mode, then you can use the Orbi system in router mode, not AP mode. Contact the ISP for help and information regarding there gateway router and bridge or modem only modes to have them help you with this.
- Number2Jan 04, 2024AspirantThanks for your quick reply, I can get the ISP gateway into bridge mode, but when I try to put the orbi into AP MODE , the Gateway and the orbi restart and then the wifi SSID comes up but no internet, so I went back to the beginning and left it alone.. but I think that I'm not getting what I'm paying for.. will the ISP come to set this up for me being that I bought the Orbi myself. again thank you for your help.
