Ronin232
Jan 09, 2024Aspirant
RBS760 dropped RBR760 Satellite from network, and satellite will not reconnect
I have the triband RBR760 system with 2 RBS760 Satellites running my network. Recently (in the past 3 or so days I think, but not totally sure) one of the satellites dropped from the network. Not "no...
Jan 09, 2024Guru - Experienced User
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
I would power OFF the ISP modem for 1 minute. Factory reset the router and power it off. Power ON the ISP modem and let it sync. Then power ON the router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
Or use the ERASE button on the routers web page to factory reset the router:
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
- Ronin232Jan 13, 2024Aspirant
Thank you for the very detailed and helpful suggest!
So, in doing first a system reboot (go back to the old "turn it off and back on again" basic step), I was able to get the satellite to reconnect properly.
However, I have now uncovered a potentially new issue....
When I logged into the system, and clicked the reboot button the system actually did a reset. When the router came back online, it automatically had be through the system setup process, setup a new admin password, etc. Not sure why that is, but I may have uncovered a new glitch that could be problematic!
Thank you again!
