dmw15's avatar
dmw15
Tutor
Aug 03, 2022
RBS760 Light on all the time
On my RBS760, the blue LED is on all the time.  The connection to that satellite is good.  How can I get that light to turn off? And if there isn't a setting for that, will NetGear please add that op...
  • dmw15's avatar
    dmw15
    Aug 03, 2022
    Well, like all electronics, I uplugged it for 30 seconds and plugged it back in.  The Blue light was on for a little bit and then went out.  Maybe that's all it needed was to be reset.  I'll keep an eye on it.  It would be nice though if they would allow a setting to disable the light and instead use an app or text notification if there is an issue with the satellite,
