dmw15
Aug 03, 2022Tutor
RBS760 Light on all the time
On my RBS760, the blue LED is on all the time. The connection to that satellite is good. How can I get that light to turn off? And if there isn't a setting for that, will NetGear please add that op...
- Aug 03, 2022
Well, like all electronics, I uplugged it for 30 seconds and plugged it back in. The Blue light was on for a little bit and then went out. Maybe that's all it needed was to be reset. I'll keep an eye on it. It would be nice though if they would allow a setting to disable the light and instead use an app or text notification if there is an issue with the satellite,
Aug 03, 2022Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Is the RBS directly connected to the RBR in back or is there a LAN Patch panel or LAN switch in between?
What CAT# lan cable are you using? CAT6 is recommended.
dmw15
Aug 03, 2022Tutor
- FURRYe38Aug 03, 2022Guru - Experienced User
Glad that was all. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
