Cypis
Mar 03, 2024Aspirant
rbs760 low speed
Has anyone dealt with the low WiFi speed of the Orbi RBS760 Satellite?
michaelkenward
Mar 03, 2024Guru - Experienced User
That is too vague a question to get much of an answer. Measured how? Through which modem/ONT/gateway? With what firmware applied to the satellite?
This also isn't the best place to ask about that hardware.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi WiFi 6 (AX) and WiFi 6E (AXE) - NETGEAR Communities
You might like to search there for messages related to your issue.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
