marwan_zakaria
Jun 01, 2023Aspirant
RBS760 Satellite is not Syncing with CBR750
I had CBR750 with two satellite RBS750 and they all worked. I need more coverage, so I purchased the most recent satellite (and the only one available) a RBS760. The problems started. I updated t...
Jun 01, 2023Guru - Experienced User
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
I updated the firmware to the absolute latest. The new satellite RBS760 does not sync the SSID and always defaults to its SSID. I have tried rebooting, updating FW and finally re-set and start from scratch. Nothing worked.
I need help.
I have V4.6.14.4 on the CBR750, and V4.6.14.3 on the RBS750, and V6.3.6.4 on the RBS760 (with message stating update failed. I did try multiple times but the update failed does not go away).
