nesta13
Dec 22, 2021Aspirant
RBS850 - Helium Miner - Making sure Armor does not block traffic going to the IP
Hi, I'm mining Helium on my home network and have set up Armor on my Orbi. I want to make sure no traffic going to the miner's IP are being blocked by Armor. Is there a way to make sure thi...
Dec 22, 2021Guru - Experienced User
You could put the miner in the orbi's DMZ. Not the most secure option but it would forwards all traffic.
nesta13
Is there a way to see if Armor is blocking any traffic for this specific IP? Might not even be a problem, I just want to be sure
- FURRYe38Dec 22, 2021Guru - Experienced User
Seems that others have seen this issue with Armor as well:
https://community.netgear.com/t5/NETGEAR-Armor/Armor-Blocking-Helium-RAK-Hotspot/m-p/2159588
