PTWA
Aug 16, 2020Star
RBS850 - How to prevent 'wired' backhaul via Sonos
My Orbi RBR850 and two RBS850 with Sonos Boost connected to RBR850 runs perfect. To increase SonosNet coverage outdoor I connected a second Boost to RBS850. This temporarily did run perfect, boosting ...
Chuck_M
Aug 31, 2020Mentor
Nice rundown.... some interesting conclusions there that I wasn't aware of.
This is most significant:
PTWA wrote:
My conclusion from experiments is that wired SONOS devices shall all be wired to the same Orbi device.
Have you changed the root node at all?
Look at this article about Sonos on another vendor's mesh system (and how they solved it)
Does anyone know if (and which version) Spanning Tree Protocol is operating/implemented on Orbi AX6000 systems?
A good article on that and Sonos:
https://en.community.sonos.com/troubleshooting-228999/sonos-and-the-spanning-tree-protocol-16973
SONOS ZonePlayers use 802.1D Spanning Tree (STP) for loop prevention between wired ZonePlayers and the wireless SonosNet Mesh Network. The Spanning Tree running on ZonePlayers is compliant with IEEE 802.1D and can inter-operate with other IEEE 802.1D and IEEE 802.1w compliant devices. Note: IEEE 802.1w is an updated version of the Spanning Tree protocol called Rapid Spanning Tree. The two types of STP protocols are compatible and 802.1w should revert to inter-operate with 802.1D devices (such as Sonos). Therefore, 802.1w Ethernet switches will work with Sonos ZonePlayers
PTWA
Sep 02, 2020Star
In case changing the root node refers to SONOS advconfig capability, I did not experiment with this.
Now I have to report that today the satellite with wired BOOST stopped working. The Orbi app showed a Network diagram with the satellite having a red dot instead of a green dot, and still a dotted line for wifi backhaul. Power off and on with BOOST wired did not resolve the issue. The satellite white light kept blinking. After removing the wired BOOST and power cycle the satellite, it was ok again. Adding the wired BOOST again resulted in the same dead state of the satellite. Router and other satellite continue unhindered.
Now I moved the BOOST, and wired it directly to the router. I have no longer any SONOS device wired to any satellite. Waiting for the result...
I may have to withdraw my earlier conclusion that it does not make a difference whether a BOOST is wired to a router, or to a satellite.
Given the current state, and my outdoor SONOS no longer shows green in the SONOS matrix, I may experiment with a second BOOST not wired but assigned root bridge via the advconfig capability.
Question is what happened to the satellite, ending up dead. It may stem from the satellite again switching from wifi to wired SONOS backhaul, but now even a slow path did not exist, since a second wired SONOS device was not in the network??? Just a (idiot?) guess... no clue how to debug this one.
- Chuck_MSep 03, 2020Mentor
Question is what happened to the satellite, ending up dead. It may stem from the satellite again switching from wifi to wired SONOS backhaul, but now even a slow path did not exist, since a second wired SONOS device was not in the network??? Just a (idiot?) guess... no clue how to debug this one.I read in one of the listed articles that the boost had to be connected directly to the RBR (not a satellite) to avoid this loopback condition.
- BucksCountyPandJan 27, 2021AspirantHas anyone figures this out?
It's absolutely crazy to me that the RBS thinks that a connected device is a wired backhaul to RBR.
I have the same issue and it's driving everyone in the house absolutely crazy. Is there a way to force the backhaul path in Orbi so it connects to a specific IP address back to a specific RBR or RBS.
I have the same issue that after time or any type of internet flapping or instability the RBS reconfigures itself to shift from wireless backhaul to Ethernet backhaul via a hard wired Sonos speaker.
Current setup
FiOS to RBR
RBR wired to RBS1 to Arc and Sub
RBR wireless to RBS 1 to Sonos One
RBR wireless to RBS 2 to Sonos One
I have about 20 Sonos speakers on Sonos net - PTWAJan 27, 2021StarLooking forward to any stable solution !
In the meantime I run S1 wireless and S2 SonosNet with two Boost devices that are both wired to RBR. All further Sonos speakers not hard wired. This setup runs smooth, however still it would be great to get rid of the long wire between RBR and Boost for Outdoor. - BucksCountyPandJan 27, 2021AspirantInteresting...
I've noticed that my
hard wired Sonos ARC to RBS
hard wired RBS to RBR never experienced this issue. It's only when an RBS is wireless backhaul to RBR that I connect a Sonos speaker hard wired to RBS is when this issue happens - PTWAJan 27, 2021StarI observe the same. To work around I hardwire Sonos devices only to RBR and do not hardwire Sonos devices to any RBS. As a result the wireless backhaul between RBR and RBS is stable.
