Dijkweide
Oct 05, 2021Aspirant
RBS850 - Out of sync - wired instead of wireless - Continuos blue circle light
I am having so many issues with my Orbi Mesh System. The last week I continously see the blue circly light on continously on 1 of the 2 satelites. Sometimes it turns off and then it happens again. It...
Dijkweide
Oct 06, 2021Aspirant
Hi Furry, thank you for your help. I have factory reset the router a few times already but not after this issue. I ended up drilling a bunch of holes in my house and just wired it. Like I said I bought this system thinking it could pass one floor in my house when placing the satelite right above the router but I was wrong. Also the second satelite now shows poor reception and it is only two rooms away. This system is probably designed for houses in the US made of wood but not for houses with brick and concrete.
Oct 06, 2021Guru - Experienced User
Ya brick and concrete will impact wifi signal for any wifi router.
