rr20552
Nov 25, 2021Apprentice
RBS850 - satellite unusable since 4.6.3.16
Since upgrading to 4.6.3.16 my satellite has been completely unusable with constant reboots and blue disconnects. Any idea on how to resolve this?
rr20552
Nov 28, 2021Apprentice
So I tried a factory reset, power down and re-setup but still having issues with the satellite.
I have also tried changing the CTS and disabling AX.
Is there a way if looking at logs specifically for the satellite?
I looked at the web interface of the satellite but couldn’t find anything?
Thanks in advance.
Thanks in advance.
Nov 29, 2021Guru - Experienced User
Wondering if you downgraded the RBS to last version of v3, then let let the RBR reupdate the RBS back to v4 if this would help any. Something I found after going back to v3 on my system, then I used the RBR to update back to v4, powered everything OFF for 1 minute then back ON. System has been stable since then.
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-Online-Update-4-6-3-16-RBR850-RBS850/m-p/2155645/highlight/true#M22357
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-Online-Update-4-6-3-16-RBR850-RBS850/m-p/2154700/highlight/true#M22256
- rr20552Dec 10, 2021ApprenticeI’ve finally managed to get to the bottom of the disconnect / reboot issue with my satellite.
For me it was related to setting the CTS to 2347 whilst having multiple concurrent FaceTime and Netflix sessions etc.
Lowering the value initially to 500 and then eventually to 2308 has stabilised the satellite and I haven’t observed a single disconnect or reboot since.
No complaints either from the wife or kids 👍🏼
The youngest previously referred to it as Poundland Wi-Fi 😂.- FURRYe38Dec 10, 2021Guru - Experienced User
Too Funny. :smileylol:
Glad you figred it out. I'll keep the different CTS value in mind.
Please mark your thread as solved so others will know.
Enjoy. 📡
