Rhoworth99's avatar
Rhoworth99
RBS850 - Wired backhaul with poor performance
Hi All   I would really appricate some guidance on this one/   I have the RBK852 with satellite system, I'm using cat6 to create a backhaul link, but on the satellite i'm getting 10% of the poten...
  • FURRYe38's avatar
    Manually download FW files.
    Start formation should work, even with a directly connection. My RBS work in Star formation. Though I use switches in between the RBR and RBS for my network.
    Try swapping RBS around to see of problem follows.
