Rhoworth99
Jul 25, 2020Aspirant
RBS850 - Wired backhaul with poor performance
Hi All I would really appricate some guidance on this one/ I have the RBK852 with satellite system, I'm using cat6 to create a backhaul link, but on the satellite i'm getting 10% of the poten...
- Jul 27, 2020
Manually download FW files.
Start formation should work, even with a directly connection. My RBS work in Star formation. Though I use switches in between the RBR and RBS for my network.
Try swapping RBS around to see of problem follows.
Rhoworth99
Jul 27, 2020Aspirant
thanks for the advice, i have temporally fixed the issue by putting a gig switch in between the RBR & RBS. I previously had it in a star setup but didn't work, in answer to your questions
is there a switch in between the RBR and RBS or is the RBS directly ethernet connected to the back of the RBR?
There wasn't, it was connected directly from the RBS to RBS, using a ethernet cable (cat6), as previously mentioned I tried a few cables as I thought I had made an error in terminating the cable.
Testing a wired connection at the RBS? i would see 80mb download & 50 upload (1gig connection)
Testing a wired connection at the remote location with out the RBS connected? i would see 948mb download and 54mb upload
I will download the firmware, when I did a firmware check the neither the RBS or RBR reported one being available. I plan to then setup the system again and remove the switch to see if there is an improvement.
Jul 27, 2020Guru - Experienced User
