Boeing
Aug 17, 2021Follower
RBS850 -100NAS vs RBS850-100EUS
Dear readers, Does anyone know the difference between the RBS850-100NAS and the 100EUS modell ? Is this only the pin construction on the power module or something else, are they interchangeable ?...
Aug 19, 2021Guru - Experienced User
Well one is for EU (RBS850-100EUS) to support EU power supply and the other is for NA (RBS850-100NAS).
Otherwise everything else is about the same.
If you get one from the USA, besure you get a dual voltage power adapters for the units.
Boeing wrote:
Dear readers,
Does anyone know the difference between the RBS850-100NAS and the 100EUS modell ? Is this only the pin construction on the power module or something else, are they interchangeable ? I would like to buy some in the US to expand my parents system in Europe. Reason, big difference in price :-) Can't imagine Netgear is making different RBS850 's for the US and Europe. Am i mistaken ?
