Orbi_Mesh_User
Jan 02, 2025Follower
RBS850- Disable 2.4Ghz on ONLY a Satellite?
I have 2 RBS850 (Orbi WiFi 6 Satellite AX6000) satellites connected to an RBR850 router. The router and both satellites are broadcasting 2.4Ghz and 5 Ghz bands. One of my RBS850 satellites is close e...
Jan 02, 2025Guru - Experienced User
Use the separate IoT network for 2.4Ghz only support for devices that seen only 2.4Ghz connections.
Orbi_Mesh_User wrote:
I have 2 RBS850 (Orbi WiFi 6 Satellite AX6000) satellites connected to an RBR850 router. The router and both satellites are broadcasting 2.4Ghz and 5 Ghz bands. One of my RBS850 satellites is close enough to interfere with a wireless speaker system that uses the 2.4Ghz band, but I need it in that specific location to connect to the other devices that rely on faster internet speeds provided by the 5Ghz signal.
Can I disable 2.4Ghz on just the one satellite? If not, are there any workarounds, such as forcing the 2.4Ghz devices to connect to a different satellite?
I do not want to disable 2.4Ghz for the whole system as I have devices that cannot connect to 5Ghz.
Below is my firmware- which I can confirm is the latest as of Jan 2, 2025
Router RBR850 V7.2.6.31 Satellite RBS850 V7.2.6.31 Satellite RBS850 V7.2.6.31
