lars83Berlin's avatar
lars83Berlin
RBS850 (2x) and RBR850 (AP) via switch
Hello all,
I use a RBR 850 in access point mode, as well as 2x RBS 850 which are connected to the RBR 850 by cable via a 24 port switch.
Problem: The RBS 850 are not visible as satellites in the RBR 850 web interface.
In the IOS app only one of the two satellites is currently displayed as connected, the other one has a magenta status (not connected). This morning both were shown as connected after I disconnected the network cable from both RBS and then reconnected them.
In the web interfaces of both RBS I see connected devices.
Now I am unsure if everything is working as it should, the behavior confuses me a bit.
Best regards
Lars
  • FURRYe38's avatar
    Be sure the RBS and RBR are connection is in the following configuration:
    https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System 📡
    The switch should be connected behind the RBR then the RBS to this switch.
    What CAT# lan cable are you using? CAT6 is recommended.
    What is the Mfr and model# of the ethernet switch in the configuration?
    NG GS-105/108v4 and GS308v3, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems.
    • lars83Berlin's avatar
      lars83Berlin
      Hi,
      thanks for your reply:
      Firmware-Version is:  V4.6.9.11
      Ethernet Cables are CAT6
      Switch is NETGEAR GS324P
      Actual the configuration is:
      AVM-Fritzbox as router is connected to the switch, RBR is connected to the switch and RBS are connected to the switch.
      • FURRYe38's avatar
        Needs to be AVM-Fritzbox as router is connected to the RBR, Then RBR is connected to the switch> and RBS are connected to the switch.
