Hogwarts
Jul 28, 2020Guide
RBS850 assigning new IP addresses to existing devices that were assigned a static IP address
I have the AX6000 RBS850 which i have had for a month. Its a nightmare. One of the issues is that i have a list of devices that need to have static IP's so i assigned them. I have had to reboo...
Jul 28, 2020Guru - Experienced User
By static do you mean set on devices or as in IP address reservation set ON the router. There is a difference.
I've got v32 loaded on my and both RBS are ethernet connected. IP address reservations for the RBS and 1 wired PC. DHCP IP address pool on mine is set for .100 thru .150 for my needs. I on'y have about 30 devices. I have a few cameras, printers and NAS which at set to static IPs outside the DHCP IP address pool. Everything else is Dynamic IP addressed assigned.
- HogwartsJul 28, 2020Guide
FURRYe38 wrote:
What Firmware version is currently loaded?By static do you mean set on devices or as in IP address reservation set ON the router. There is a difference.
MY DHCP adress range is the default 192.168.1.2 to 192.168.1.254. and my Firmware Version is
V3.2.15.25_1.3.15.under the advanced tab "attahced devices" i have added about a dozon adress reservations. They are in the same range as the default. Are you suggesting that the router will step on "RESERVATIONS" because they are in the range? I woudl hope not.
- FURRYe38Jul 28, 2020Guru - Experienced User
No. Reservations should be with in the routers iP address pool. Static IPs belong out side the pool which you don't have room for that.
- HogwartsJul 28, 2020GuideI don’t think I understand the terminology clearly enough to understand what you said? What is the difference between a static ip and a reservation. I thought creating a reservation, Creates a static IP. Is that not true? What I want is for these devices to always have the same up adresses and to never get assigned a different one.
