Orbi-CA
Apr 21, 2020Aspirant
RBS850 broadcasting WPA2 security on 2.4 GHz and Open security on 5Ghz
One of my my satellites is broadcasting WPA2 security for the 2.4Ghz channel and Open security for the 5Ghz channe. I did a wirelss scan using the Wireless Diagnostics tool on my mac and I can see th...
Apr 21, 2020Guru - Experienced User
Sounds like the one RBS hasn't sycned correctly. Do other RBS appear working correctly if you turn OFF the 1 RBS that isn't.
Factory reset the 1 RBS and resync it to the RBR.
