Dazza762
Apr 04, 2024Luminary
RBS850 compatibility with RBR750
 Hi,  I have an RBR750 system with 2 RBS750 satellites. We've moved to a bigger house and the system isn't quite covering the whole property. You can't seem to buy additional satellites for the 750 sy...
- Apr 06, 2024FURRYe38 Finally seem to have it fixed. The issue with the FW was that I was trying to update the RBS850 to V7.2.6.21 as that's what the 750 system is on but the V7 for the 850 is V7.2.6.31. Have now updated the 850 successfully to V7 and everything seems to be working as it should. For some reason though, I can no longer log into the web UI for the 850 satellite since updating it to V7.2.6.31
Dazza762
It's big enough that my current system has a dead zone at the rear of the house (inside) so I just want to double check if I get a RBS850 it could be added to the current 750 system. The compatibility table suggests it would but I just wanted to check with the guys and gals on here.
Apr 04, 2024Guru - Experienced User
There a size in sq feet?
- Dazza762Apr 04, 2024LuminaryAbout 7000 square foot over 3 floors. - FURRYe38Apr 04, 2024Guru - Experienced UserRight, ya, the RBR and two RBS are probably struggling with that size of home. One or two additional RBS should help. 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected. - Dazza762Apr 04, 2024LuminaryThanks for the response but I just need to know if a RBS850 can be added to a RBR750 system.
