Dazza762
Apr 04, 2024Luminary
RBS850 compatibility with RBR750
Hi, I have an RBR750 system with 2 RBS750 satellites. We've moved to a bigger house and the system isn't quite covering the whole property. You can't seem to buy additional satellites for the 750 sy...
- Apr 06, 2024
FURRYe38 Finally seem to have it fixed. The issue with the FW was that I was trying to update the RBS850 to V7.2.6.21 as that's what the 750 system is on but the V7 for the 850 is V7.2.6.31. Have now updated the 850 successfully to V7 and everything seems to be working as it should.
For some reason though, I can no longer log into the web UI for the 850 satellite since updating it to V7.2.6.31
Apr 05, 2024Guru - Experienced User
Can try wirelessly syncing the incoming RBS to the RBR750. I would first turn OFF ALL existing RBS. Then with incoming RBS in same room as the RBR, one at a time, try wireless syncing. If one fails to not fully connect, then ya, ethernet connect the RBS to the back of the RBR and log in with the IP address given from the RBR. Log in maybe admin and password if it doesn't sync fully.
