Dazza762
Apr 04, 2024Luminary
RBS850 compatibility with RBR750
Hi, I have an RBR750 system with 2 RBS750 satellites. We've moved to a bigger house and the system isn't quite covering the whole property. You can't seem to buy additional satellites for the 750 sy...
- Apr 06, 2024
FURRYe38 Finally seem to have it fixed. The issue with the FW was that I was trying to update the RBS850 to V7.2.6.21 as that's what the 750 system is on but the V7 for the 850 is V7.2.6.31. Have now updated the 850 successfully to V7 and everything seems to be working as it should.
For some reason though, I can no longer log into the web UI for the 850 satellite since updating it to V7.2.6.31
Apr 05, 2024Guru - Experienced User
Try very last v4 version of FW.
Or try this v4 version first:
- Dazza762Apr 06, 2024Luminary
- FURRYe38Apr 06, 2024Guru - Experienced User
I see, NG snuck one in on us. You should have RBS access, however since the 750 series isn't on v.31, and the RBS is, possible not working for the WEB UI. You can downgrade the RBS to v.21 or I presume in near future, the 850 series will see the v.31 FW then you could upgrade the 750 series and all be on same version of FW.
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
